How to turn off selection window
Message 1 of 8
A selection window will pop up and asking my selection every time. How could I turn this function off? I have already set the system variable PICKFIRST=1
Replies (7)
Message 2 of 8
user181
You need to turn off the selectioncycling by selecting the button show in included pic
Message 3 of 8
which one should I select?
Message 4 of 8
AllenJessup
Make sure you have it turned on in the customization menu (3 lines at lower right).
Allen Jessup
CAD Manager - Designer
Message 5 of 8
user181
Click the 3 bars on the lower right of screen and make sure selection cycling has a check. That will put the icon on status bar. Or change selectioncyling system variable to 0
Message 6 of 8
AllenJessup
You can also type SELECTIONCYCLING and set the value.
Value Description
0  The display options are turned off
1  A badge displays when you hover over objects that overlap
2  Both a badge and the Selection dialog box displays
Allen Jessup
Message 7 of 8
thank you. I use civil 3d 2014. Look at my screen shot. Why there is no 3 bar button?
Message 8 of 8
AllenJessup
Allen Jessup
