How to collectively create subassembly in Autodesk Subassembly Composer?
How can I work collectively on a subassembly Autodesk Subassembly Composer for Civil 3D?
What methods are there?
Artyom Durasov
Solved by copper.chadwick. Go to Solution.
Great idea and thanks for creating a great post. Creating a subassembly and saving a (PKT) file while collaborating with multiple users is not a function of Subassembly Composer.
Conventional file management is available such as storing in a common location and multiple users opening/ sharing the (PKT) file is available, but not concurrently.
In example, one person can create the subassembly "saveas" a *.pkt file and then share that file on a network for a second user to then open it, however both people can not have it open at the same time and maintain the integrity of the subassembly file.
Heres an Autodesk Knowledge Network article describing using Subassembly Composer.
Also here is an article regarding Exporting Custom Subassemblies.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
I hope this post has helped. Thank you for a great post, with a very good question.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question. Doing this helps the whole community in the Civil 3D Forums, to identify solutions to issues that effect it, and can provide clarification to those issues. Thanks for your participation in the forums it helps everyone to bring these kinds of questions forward!
