HOW TO CREATE longitudinal l SECTION AT EVERY 1KM
shashirekha2015
shashirekha2015
i want to create longitudinal section at every 1km.i am unable to create that.please anyone knows help me out.
shashirekha
wfberry
Where to begin.
Have you ever made a Long Section before?
If yes just make them 1 KM apart.
Bill
neilyj666
Do you mean cross sections rather than longitudinal?
Create an alignment along the length of your project - doesn't have to be anything special -  and then draw polylines where you want the sections and then use the cross section tools using these exisitng polylines for position of the sections
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
user181
Hi @shashirekha2015 if you already have an alignment and surfaces or corridors you can select SAMPLE LINES from the ribbon and then select your alignment. Then from the sample lines toolbar click the down arrow as shown in pic and select by range of stations. Then in the next dialog you can set your increments (see pic). After it creates the sample lines go to the ribbon and choose the SECTION VIEWS > Create Multiple Section Views. Follow the dialog boxes and then pick where to insert the section views. You will need to have styles set up or use the default styles.
