Civil 3D Forum
how to creat random points
8 REPLIES 8
Message 1 of 9
2804 Views, 8 Replies
hello Friends how r u ? this is santosh rathore I have some problem using in civil 3d, some one tell me how is creat automatic random points on layout plan in every junctions
Santosh Rathre
Santosh Rathre
8 REPLIES 8
Message 2 of 9
I'm not sure what you're trying to accomplish?
Do you want to set cogo points in a grid pattern? Say, a 25x25 grid? Do they need elevations (all the same or different)?
If you want random points, just use create points manual. If you have a surface, you can use create points surface on grid.
Reid
Reid
Message 3 of 9
There is also a command to create random points on a surface.
John Mayo, PE
Win 7 64, C3D & RD 2010
Core i7 920, 6 GB DDR3
Quadro FX 1700
John Mayo, PE
Quadro FX 1700
Message 4 of 9
hello sir i sending you a drawing u can see it. I can create random point on the drawing manualy i but i don't know how to create Automatic random on the drawing but is possible. can u tell me how is possible
Message 5 of 9
Hi santosh,
You will get a much clearer answer if you clarify what you mean by
"random points" and what you need them for.
As it stands you are asking readers to guess what you want and so it's
near impossible to give a helpful answer.
Laurie Comerford
Hi santosh,
Laurie Comerford
Message 6 of 9
k sir im working on sewer system design i want to make node numbers automatic on the drawing. for data sheet purpose
Message 7 of 9
sir im working on sewer system design i want to make node numbers automatic on the drawing. for data sheet purpose can u tell me how is possible create automatic random point on the drawing
Message 8 of 9
AllenJessup
AllenJessup
I don't know of any way to automatically create points at every intersection and end of a network like you show. You might try asking in the Map 3D group to see if there is a way in map to create AutoCAD points on a network. Then you could convert them all to C3D points.
Allen
Allen Jessup
CAD Manager - Designer
Allen
Allen Jessup
Message 9 of 9
To me, those are not "random". They are specific to each node intersection of the lines. Do you need elevations associated with a surface at those nodes?
If those are polylines, points can be added to each node via the create points commands. Numbering can be made sequential if needed. Just be sure not to duplicate points at an intersection.
Reid
Reid
Rail Community
