hi everyone,
some time we receive a file of exploded cogo points ( exploded one time)
and some time we explode the cogo points to send some one who is not using the civil 3D.
so is there any possible way to retrieve the cogo points from the same exploded cogo points?
Solved by samir_rezk. Go to Solution.
Samir,
That looks cool! I haven't used Dynamo, don't even know anything about it. But I do notice that your DYN Script has 1370 lines of code. How long did it take you to write it?
Dave
Dave Stoll
Las Vegas, Nevada
Samir Rezk
Technical Support Specialist
If you have access to the LDD database just re-import (Google, 'Import Points from Land Desktop Database') them into your Civil 3D dwg.
Many reasons listed here for not exploding points but everyone missed how much time is devoted to this post and trying to put them back together. 🙂
Note C3D cogo points make much better labels than AutoCAD text. Master the styles and you will never need text.
John Mayo
Samir,
I didn't quite scroll all the way to the bottom. 1382 Lines.
Dave
Dave Stoll
Las Vegas, Nevada
That's super impressive @samir_rezk !
Thanks everyone for your insights here!
@Anonymous Did you find the suggestions helpful to solve your problem?
brother Samir,
your solution is absolutely right.
but my civil 3d do not have this tool.
i see you have attached a file(dynamo.dyn) how to use this with civil 3d 2018.
Hi @Anonymous
Dynamo is a visual scripting application available as a separate extension download for Civil 3D version 2020 only. Not available for 2018 unfortunately. If you like to send me your drawing, I can use it on my machine and send you back an ASCII file for reimport in your 2018 drawing.
let me know,
Samir Rezk
Samir Rezk
hay bro samir.
i have civil 3d 2021 with me can you send me the dynamo application.
Hi @Anonymous
The graph is attached to Message 19!
Samir Rezk
bro how to install this file with civil 3D.
i cant run this file in civil 3D.
This might help.
Allen Jessup
CAD Manager - Designer
Do you have administrative rights? If not. You'll have to get your IT to run it.
Allen Jessup
Yes. I have administrative rights. Can you send me this appication in my mail. qmahmood@built.com.sa.
This file dynamo file appears as an autocad file. And deirectly opened in cad as cad file.
May be my downloaded version is corrupted so please send the daynamo as download link etc.
Dynamo should be available on your account page.
Allen Jessup
