How to Automatically align multiple texts to the closest line.
curtisQ4SKF
curtisQ4SKF
Community Visitor
Community Visitor
Hi there,
I have thousands of text along curbs and such, as seen in the image below that I have to manually torient to the closest line which will take me hours.
Is there a way I could get all the selected text to align to the closest line?
I wouldn't mind going through and moving the text to the line.  I just want to get the torient function out of the process as it is taking forever to manually align
Much Appreciated
tcorey
If those were blocks, they could include an align grip where you just point to a linear object and the block aligns to it. It's pretty sweet.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
jeff.wangD95HG
I think you need to write code for it. I am curious about it as well
I have developed a workflow that does something similar but for cogo points. If you are able to convert those text to cogo points attached to the ends of the line then I might be able to help you.
chriscowgill7373
Are you looking for like a 1 click rotate command?  I too have something for COGO points, but I also have something I use for street names to align them to ROW, it requires 2 points though.  It probably could be rewritten to automatically assume the insertion point and then the only point you are selecting is the rotation angle.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
