Civil 3D Forum
How to add Tangent Direction in and out of non-tangent curves in Mapcheck report
10 REPLIES 10
Message 1 of 11
tcorey
826 Views, 10 Replies
Does anyone know how to do this? The various mapcheck reports in Civil 3D report radial bearings, but not tangents. It's easy to calculate and label, but it's not easy to report.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
10 REPLIES 10
Message 2 of 11
rl_jackson
in reply to: tcorey
Interesting question? Just watching this one.
Rick Jackson
Survey CAD Technician VI
Message 3 of 11
Jeff_M
in reply to: tcorey
Tim, if this is in regards to the Mapcheck command then I don't think we can add the tangent directions as that is all hardcoded. However, the directions could be added to the Parcel Mapcheck report. And, with a bit of added testing, only add them when the arc is non-tangent.
Message 4 of 11
tcorey
in reply to: Jeff_M
@Jeff_M ,Parcel Mapcheck report will work. Can you point me in the right direction? I searched the xsl files and there is one for Parcel Inverse, but not for Parcel Mapcheck.
Tim Corey
Redding, CA
Message 5 of 11
Jeff_M
in reply to: tcorey
Tim, this is a .NET report written in VB.NET.
Message 6 of 11
tcorey
in reply to: Jeff_M
Thanks, Jeff.
Tim Corey
Redding, CA
Message 7 of 11
Jeff_M
in reply to: tcorey
@tcorey , I had some time to work on this this morning.  I don't check to see if a curve is non-tangent, so it shows the TangentIn & TangentOut for all curves. And it fails when the arc is exactly 180 degrees (for now, it's a work in progress).
I added 2 Public fields for the new In & Out values, and added the following to the end of the FillData of the SegmentCurve file:
        ''calculate the Tangent Directions
        Dim E As Double
        E = oSegmentCurve.Tangent * (Math.Tan(oSegmentCurve.Delta / 4.0))
        Dim chordlength As Double
        chordlength = Math.Sqrt((oSegmentCurve.EndY - oSegmentCurve.StartY) ^ 2 + (oSegmentCurve.EndX - oSegmentCurve.StartX) ^ 2)
        Dim chorddirection As Double
        chorddirection = Math.PI / 2 - ReportUtilities.CalcDirRad(startNorth, startEast, endNorth, endEast)
        Dim MidChord_North As Double
        Dim MidChord_East As Double
        ParcelMapCheck_ExtractData.CalculateNextPoint(startNorth, startEast, MidChord_North, MidChord_East, chorddirection, chordlength / 2.0)
        Dim midangle As Double
        midangle = Math.PI / 2 - ReportUtilities.CalcDirRad(centerNorth, centerEast, MidChord_North, MidChord_East)
        Dim PI_North As Double
        Dim PI_East As Double
        ParcelMapCheck_ExtractData.CalculateNextPoint(centerNorth, centerEast, PI_North, PI_East, midangle, oSegmentCurve.Radius + E)
        If Delta < Math.PI Then
            TangentIn = ParcelMapCheck_ExtractData.RoundDirection_Parcel(startNorth, startEast, PI_North, PI_East)
            TangentOut = ParcelMapCheck_ExtractData.RoundDirection_Parcel(PI_North, PI_East, endNorth, endEast)
        Else
            TangentIn = ParcelMapCheck_ExtractData.RoundDirection_Parcel(PI_North, PI_East, startNorth, startEast)
            TangentOut = ParcelMapCheck_ExtractData.RoundDirection_Parcel(endNorth, endEast, PI_North, PI_East)
        End If
 Then added this after the Course In & Course Out section of the ReportForm_ParcelMapCheck:
                AppendOneRecordInTable(oHtmlWriter,
                            "Tangent In: " +
                                ParcelMapCheck_ExtractData.FormatDirSettings_Parcel(segCurve.TangentIn),
                            "Tangent Out " +
                                ParcelMapCheck_ExtractData.FormatDirSettings_Parcel(segCurve.TangentOut))
And sample output:
Segment# 2: Line
Course: N55° 55' 18"E Length: 469.987'
North: 15,983.2104' East: 14,882.8781'
Segment# 3: Curve
Length: 570.687' Radius: 281.217'
Delta: 116.2730 (d) Tangent: 452.437'
Chord: 477.680' Course: S82° 04' 41"E
Course In: S50° 12' 52"E Course Out: N66° 03' 31"E
Tangent In: N39° 47' 08"E Tangent Out S23° 56' 29"E
RP North: 15,803.2551' East: 15,098.9779'
End North: 15,917.3735' East: 15,355.9993'
Segment# 4: Curve
Length: 626.460' Radius: 433.700'
Delta: 82.7612 (d) Tangent: 382.097'
Chord: 573.402' Course: S65° 19' 20"E
Course In: N66° 03' 31"E Course Out: S16° 42' 10"E
Tangent In: S23° 56' 29"E Tangent Out N73° 17' 50"E
RP North: 16,093.3698' East: 15,752.3842'
End North: 15,677.9682' East: 15,877.0326'
Message 8 of 11
tcorey
in reply to: Jeff_M
This subject has come around again.
I have found the SegmentCurve.vb file for Civil 3D 2022.
@Jeff_M , I don't know where into the vb file to copy your code.
Thanks for any help...
Tim
Tim Corey
Redding, CA
Message 9 of 11
Jeff_M
in reply to: tcorey
@tcorey Tim, attached is a zip with the 2 .vb files I edited. I added comments to the 3 areas I added code, 2 in the segmentcurve and 1 in the other
Message 10 of 11
tcoreyKM7TG
in reply to: Jeff_M
Thanks, Jeff. To be clear, should this change the output from Analysis tab of Parcel Properties or within the report, Parcel Map Check Report?
Message 11 of 11
Jeff_M
in reply to: tcoreyKM7TG
These edits are for the ParcelMapCheck report. I have not looked into whether this may also affect the Parcel Analysis. If you overwrite the OOTB report DLL it just might...I always keep my customized reports separate from the stock rpeorts.
Rail Community
