- Mute
- Permalink
- Report
Hello learned scholars and helpful people;
I am doing a gravel pit reclamation where they want me to contour the reclaimed site. I have a slope of 20:1 from a specific offset on the west side, and 3:1 slopes from specific offsets on the other three sides.
I have an original ground surface built from survey data, and then another surface called overburden which was modeled using the outer points of the original ground surface and elevations provided by about 8 or 9 test holes (Sketchy but it's all I have.) I want to project the outer slopes down to the overburden surface and then contour that to show them what the area will look like after reclamation. I also have data for the gravel depth (below the overburden) which would be cool to model because then I could get volumes but for now I would be ecstatic to be able to do my slopes.
From the twelve thousand videos I have watched, it seems that I need to make breaklines out of my tops of slopes (feature lines) in order to assimilate them into the model, otherwise they are at 0 elevation and I can't project slopes. (I even tried drawing a 3D polyline from each end of the model but of course that isn't accurate. I have made a breakline from my feature line on the west side, and it gets absorbed by the model and looks nice, but now I can't figure out how to project from THAT line down to the overburden surface as there is no longer a feature line to project from.
I hope all of this makes sense. Any help, videos, anything would be very much appreciated.
Thank you
Liesl
