how can solve connect the daylight to last target surface in subassembly composer?
giscivil92
Message 1 of 19
giscivil92
Hi. how can solve connect the daylight to the last target surface in the subassembly composer?
Replies (18)
Message 2 of 19
fcernst
It doesn’t look like you’re even daylighting at 38.30..
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 3 of 19
giscivil92
Actually, 38.30 is the elevation target but I want to connect daylight to last surface
@fcernst
Message 4 of 19
fcernst
That’s just typical slope/elevation target scenario..then typical daylight scenario.. after the road/whatever ..not a multi-intercept daylight scenario.
For a multi scenario at 4:1 send an auxiliary link out at 4:1 for a distance well past all the possible surface intersections.. then daylight back to pick up the last daylight intersection point
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 5 of 19
giscivil92
I didn't understand, what do you mean!?
Message 6 of 19
fcernst
The 4:1 was just an arbitrary slope….example
You don’t have a daylight multi-intercept scenario here…….
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 7 of 19
giscivil92
I shredded the pkt you can check the file!
I have tried to solve it but I couldn't!
Message 8 of 19
BrianHailey
This is what @fcernst was recommending, which is brilliant.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 9 of 19
giscivil92
@BrianHailey but I don't know how I do it?
Message 10 of 19
BrianHailey
Create an axillary point that extends way out beyond your surface.
And then create a point daylighting back the other direction from that axillary point.
GEI Consultants
My Civil 3D Blog
Message 11 of 19
giscivil92
@BrianHailey
I did it, but the problem was not solved!
Message 12 of 19
giscivil92
Unfortunately, I have not solved this problem yet!
Message 13 of 19
nkiakas
hi @giscivil92
This video i am sure will help you
Its exactly what to you want
https://youtu.be/hUqrQhkHD5g?si=eFyqbzyWXWl7N6_k
Message 14 of 19
giscivil92
I have been attempting but I wasn't successful could you check please check the pkt!?
Message 15 of 19
nkiakas
Yes i will look in your subassembly.
Could you please also share the concept of this typical section?
I want to know exactly how it works.
Do you have any sketch from your typical section?
Message 16 of 19
giscivil92
@nkiakas My apologies that I can not share the file!
Message 17 of 19
BrianHailey
@giscivil92 change the extension of the .pkt file to .zip and then share it.
GEI Consultants
My Civil 3D Blog
Message 18 of 19
giscivil92
@BrianHailey
I shared it.
Message 19 of 19
BrianHailey
Since you haven't explained what exactly you want I'm going to assume that you want L102 in your subassembly to daylight to the last point that it would cross the surface target EG.
To do this, create an axillary point from P60 at the same slope that you would daylight so that it extends way beyond the limits of your surface. From that axillary point, create another axillary point that slopes to surface back along the path of the original axillary link. Now, create point P91 at that axillary point and then link L102 between point P60 and P91 and you're done.
In essence, go out beyond your surface and then daylight back, that's your last surface crossing. Now create a point there and link it to the previous point.
GEI Consultants
My Civil 3D Blog
