Civil 3D Forum
How can I import a .TIF map data file into AutoCad, Revit, or Civil 3D?
6 REPLIES 6
garethmac600
541 Views, 6 Replies
As the title says, I have a .TIF map data file given to us from a client. I need to import it into either revit, ACAD, Civil3D. is there a way to do this without an add on? can i convert it to a file type that is usable? everything i have found so far has not solved this problem.
Thanks.
6 REPLIES 6
Pointdump
in reply to: garethmac600
Hi Gareth,
Tiff's shouldn't be a problem. What have you tried so far?
In Civil 3D you can use MAPIINSERT or MAPCONNECT. If you have Raster Design, use IINSERT.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Jeew-m
Did you try THIS one?
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
garethmac600
in reply to: Pointdump
mapinsert returns the error that ''command is not possible in modelspace#. when i activate the online map and try to add the .tif file via the 'insert image'  button on the command tab, no file explorer opens to allow me to select the file. instead autocad asks for the file name however when typing in the file name it returns the same error message 'command not possible in modelspace.
the .tif file is only 751kb so i don't think size is an issue.
garethmac600
in reply to: Jeew-m
I did try this, thanks, however it yields the same result as mentioned in my other comment
Pointdump
Gareth,
Did you try MAPCONNECT?
Please post your rogue tif.
Dave
Dave Stoll
Las Vegas, Nevada
AllenJessup
It's beginning to sound like the TIF may be damaged. Can you open it in a raster editor?
What's it supposed to contain? Is it supposed to be Georeferenced?
Allen Jessup
CAD Manager - Designer
Rail Community
