Goal: I want to be able to have 2 different pipe styles for a single pipe in the same drawing. If I change the pipe style for Pipe A to "Crossing" then that pipe shows up as a crossing in two separate profiles. I want to be able to show it as a crossing in one profile and normal stretch of run in the other.
Is this impossible? From what I'm seeing, a singular pipe can only have 1 style associated.
Solved by ToddRogers-WPM. Go to Solution.
Go to your Profile View Properties. Click on Pipe Networks tab. For that pipe, assign an Override style to it.
Yes you can, but only in a profile. On the profile view properties there is a tab for Pipe Networks. There is a column showing the current pipe style and a column for a Style Override. Here you can apply an new style to use in that profile that will override the given to the pipe itself.
