Civil 3D Forum
How can I have 2 different pipe styles with the same pipe?
3 REPLIES 3
1346 Views, 3 Replies
Goal: I want to be able to have 2 different pipe styles for a single pipe in the same drawing. If I change the pipe style for Pipe A to "Crossing" then that pipe shows up as a crossing in two separate profiles. I want to be able to show it as a crossing in one profile and normal stretch of run in the other.
Is this impossible? From what I'm seeing, a singular pipe can only have 1 style associated.
Labels (4)
3 REPLIES 3
ToddRogers-WPM
Go to your Profile View Properties. Click on Pipe Networks tab. For that pipe, assign an Override style to it.
Todd Rogers
MMcCall402
Yes you can, but only in a profile.  On the profile view properties there is a tab for Pipe Networks.  There is a column showing the current pipe style and a column for a Style Override. Here you can apply an new style to use in that profile  that will override the given to the pipe itself.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
in reply to: ToddRogers-WPM
I knew there was a way! thank you
Rail Community
