Civil 3D Forum
How can I create a band set similar to the attached image?
6 REPLIES 6
616 Views, 6 Replies
Labels (1)
6 REPLIES 6
Udo_Huebner
Yes, you can create such a representation with a customized band set.
Toolspace>Settings>Profile View > Band Syles >Band Sets > New
or
Command: EditGraphProperties >Bands >Band Type>add >>
What exactly is causing you problems, the title text with the vertical text elements or the content of the band?
The display of stations and elevation values is not problematic. But where does the number come from? This could be taken from suitably named "Sample Line Name" or from pipe Data.
Do you have a sample data set for us that just needs to be corrected, or are you at the very beginning?
Gruß Udo Hübner (CAD-Huebner)
in reply to: Udo_Huebner
Thanks for the reply
I have two series of points that I have to draw the profile of these two groups of points separately. And the information below the profile should be the station number - the height of the first point group - the height of the second point group - the difference in height of the first and second groups - the distance of the point from the previous point - the slope between the two points and the point distance from the beginning I do not know how to do this. Please help I attach two point groups
please help me 🙏
Udo_Huebner
  • It's not done with a few words but will need basic training or at least several video tutorials.
    This basic knowledge you should have:
    How to import points
    Of to connect points to a feature line
    How to create an alignment from a Feature line
    How to create an assembly with Subassembly.LinkWidthAndSlope
    How to create a corridor
    How to create a surface from the corridor
    How to create a surface profile
    How to create a profile view
    How to set up a band style for station or elevation
    How to create a band set
What of these points do you already know and where do you need additional help?
Udo_Huebner
Here is a sample drawing only using styles from "_AutoCAD Civil 3D (Metric) NCS.dwt".
Took about 30min to create. Now fine-tuning should be the next step. But here is end of the day.
Hello, thanks for the helpful answer Can I do the steps for taking a photo and sending it to me?
Rail Community
