Horizontal scale in a profile
MatthewB80097
MatthewB80097
In the edit profile view style under graph is it possible to change the horizontal scale so that it can be made smaller. I.e so that 1m appears as 0.25m. It can be done vertically but can it be done horizontally?
I have a long section profile that is around 2 miles long and need to be able to fit it ideally onto a couple of sheets @Anonymous but the horizontal and vertical geometry, chainage, existing ground levels and proposed ground levels in the bands has to be clearly legible.
Do I have to play in the main drawing settings somewhere?
MMcCall402
The horizontal scale is whatever the drawing, or viewport, scale is.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
tboehler
After you layout the horizontal scale of your viewports adjust the vertical scale to a reasonable scale for the layout.  then it's all about profile styles.  Horiz. and Vert. Grid spacing and such.
