Is it possible hide triangles from the surface?
when the crosshair is on the surface shows the triangles
but when crosshair isn't on the surface then the surface looks good.
So is it possible to do that triangles always hiding?
Solved by AllenJessup. Go to Solution.
You have to edit the surface style. You have to turn off the visibility of the triangles in the model view. I show you a picture (sorry, my C3D is in spanish...)
Yes, it is. You can activate the contours if you don't want to see the triangles. Try to activate another components and choose the best one for you
Yes. Go to the Selection tab in Options and uncheck "When no command is active" under Selection Preview.
Allen Jessup
CAD Manager - Designer
