You might want to try the Reference Editor application. The setting may
be "handle only" and you can change it to Name & Handle, this might
resolve your issue for that dwg.
Lisa Pohlmeyer
Engineer Assoc.
Williamson County, TX
lpohlmeyer at wilco dot org
Civil 3D 2009 SP2
Dell T3400 Quad Core, 2.4Ghz, 4Gb RAM
Nvidia Quadro FX 1700 - Performance Drivers
elittleton73 wrote:
> I have a file with a broken reference. When I try to open the original
> drawing, almost everything loads. But then the program just gets hung
> up. I started a new drawing and inserted the original drawing into it.
> Most of the stuff comes in okay. But I get the BIG WORDS that say there
> is a broken reference. So I try the "Repair Broken Reference" option and
> it gets hung up here too. I have researched and read and have found no
> solutions. I really need to get this fixed. The broken reference which
> is the surface works fine in other drawings. Is there anywhere I can
> edit the reference to tell it where to look. Currently it is looking in
> "C:\Documents and Settings\littlee\Local Settings\Application
> Data\Autodesk\C3D 2009\enu\Template\Drawing Name.dwg." I'm using C3D 2009.
