Gutter flow line feature not used in curb return top surf DTM
PeterKozub
Message 1 of 17
PeterKozub
Hi all
I have been working thru the tutorials and the intersection wizard is a great constraining tool
to make intersections Its not a silly gizmo so far anyways
Thus far  its seems to automate well all the offset aligns and profiles so far in my
testing.
Autodesk inventor is so constraining it hard to draw a line with out tightening your belt and
swearing of extra cheese pizza to poke fun at inventor im a true beginner.....
But back to the point to make a top surf dtm Tin see attached  JPG and drawing
I seems that all goes well until the the white circled area
please review the attached JPG
and the tutorial drawing
to see flow line gutter feature in not being used to make the top Surf DTM tin
Zoom into the attached DWG to the white circle
C3D 2017 will not save view on close so some zoom pan is required sorry
I added flow line gutter feature as a break line to surf definition and the triangles still seen odd in triangulation.
maybe i will try again tomorrow.
i suspect that in these areas a feature line is required to further control top surf dtm  beyond using just links as breaks in the surf DTM
Pete
Computer
Xi Computer S/N: 037019
Intel Core i7-2600K CPU @ 3.40GHZ
Mem 24.0 GB
Win 7 64.0 Bit
12 Gig Video Card NVIDIA K6000
2 4k Monitors display port
Autodesk C3D 2017 subscription Service auto update
HP T120 Roll feed 24" plotter.
Replies (16)
Message 2 of 17
Jeff_M
Without opening the drawing, my first suggestion would be to tighten up the Frequency for curves in the curb return region. I typically use 2', sometimes 1'
Message 3 of 17
BrianHailey
You haven't added the flowline of the curb to your surface. In your corridor surfaces, you only have the top links added. When you add links, these are the lines that run perpendicular to the baseline along the section. The featurelines are the ones that run between the sections. To find out which point codes to add as featurelines, look in the help file for the subassemblies you are using.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 4 of 17
Joe-Bouza
I could be wrong but looking at your image it appears that a curb subassembly is still running through the intersection. I'm probably wrong - you are in good hands with Jeff & Brian
Joe Bouza
Message 5 of 17
PeterKozub
I tried adding Flange, Flow line and top curb  feature lines to the surface definition
the tin still was very odd and i would say worse then using links only.
I found using manual add lines to tin  made a proper model even thou at meet of flange to ETW
at curb EC a odd dip is there and a manual edit of the curb profile FG is required
but things are very close.
The tin modeler is Nearest Neighbor Tin IN Action
Nearest Neighbor Tin IN Action is a OOps in this case the other way as Jeff M mention is to turn up the frequency so nearest neighbor will work
Please review attached JPGS
Message 6 of 17
PeterKozub
Well im kind of C3D 2017 worn out
so i think i will torture myself with Autodesk inventor 2018 for a while to make C3D 2017 look easy/normal
Regards
Message 7 of 17
fcernst
You will want to increase the frequency no matter if you use just top links, or if you want to use feature lines in the surface definition.
Because if you don't, the surface built from the featurelines will still have long chords that do not form and model the curb return well.
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 8 of 17
Jeff_M
Something to consider...what happens when you need to modify the design? All of those manual edits will no longer be valid. My rule of thumb is to NEVER modify the corridor surface directly. If I need to make edits, I will edit the corridor to get the surface right for it and paste the surface into a new surface, then fine tune things in that surface.
Message 9 of 17
PeterKozub
It looks like turn up the frequency is the solution
better than adding manual edits to the surface for those edits will fall apart if the corridor is changed and the old edits
make no connection to other new tin lines
At plot will have to use say every ten meters and i guess every 5 meters in intersection
Increasing frequency would also show odd dips humps in asphalt that require edits to the FG profile for curb.
So the additional busyness of increasing frequency has a additional benefit of revealing odd pavement slopes.
Pete
Message 10 of 17
fcernst
Increasing frequency would also show odd dips humps in asphalt that require edits to the FG profile for curb...
Not necessarily..you could fly right over grade breaks in the baseline profile geometry..if you don't have the baseline profile geometry setting toggled on also under Frequency.
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 11 of 17
PeterKozub
Take a look at the end of curve X fall for pavement
I don't thing the pavement contractor would make this and would take this Cad model out by eye
Fequency at 0_25 meters look at odd pave X fall.JPGOver the top frequency would rather control tin with feature lines around tight Curb Returns.JPG
All these extra sections are bogging down my computer so i think there may be a future in adding features lines
to control the tin corridor
i just can't make it work today maybe try again tomorrow.
Please review attached Jpgs
Regards
Message 12 of 17
fcernst
You've got Primary crown maintained..sounds like you might like the way all Crowns maintained would look.
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 13 of 17
PeterKozub
Hi all
I found a work solution to help nearest neighbor tinning in corridor Curbs
for when links fail to control triangulation
Auto extract dynamic feature line from corridor
The use of increased corridor frequency is not required and thus no bogging down computer
Extract
Gutter flow
Gutter Top
Gutter Flange
and add to surface definition
These feature lines are supposed to be linked to corridor have not moved corridor around yet
Please examine attached images
It looks like just auto corridor feature lines are needed mostly on curb returns
The bonus of the corridor feature line is the Flow line goes to survey data collector
The surveyor just picks the 3d poly on the data collector screen to stake a 1.0 m O/S for the concrete curb machine
No more profiles or alignments or templates to build / muck up in the data collector just a happy surveyor = less stress
Carlson Surve Ce data collector can stake a 3d poly and show CL station and o/s to 3d poly
Pete
Message 14 of 17
fcernst
No! You don't need to extract the featurelines to use them in a corridor surface.. as was mentioned before above.
This latest surface from you does not look very good:
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 15 of 17
PeterKozub
That is the before Dynamic Feature lines are added to control nearest neighbor Tinning
I don't now how to insert a image.
Please look at
the other after images
The surveyors need this 3D poly to stake the curb anyways
I have not tested the dynamic nature of the extracted 3D polys yet maybe tomorrow
Message 16 of 17
PeterKozub
I did a basic test and draged the intersection north and the corridor updated
the bonus is the extracted corridor flange ,flow line , top curb corridor feature updated properly due to the dynamic link to the corridor.
absolutely cool....
These updated feature lines again are further applied properly in the edit history for the top surface road. again cool this is one i was
worried might get broken until now
So no need to increase corridor frequency and bog down your computer.
This controlled the nearest neighbor tin algorithm used by top surface links making undesirable triangles from top curb to
flange curb etc.
and the surveyors get a very simple 3d poly line feature object to stake in there data collectors.
Message 17 of 17
fcernst
Ughh..you're not using the software elegantly. Dynamic featurlines are not meant to use as surface definitions for your Corridor surface...use the Corridor featurlines as previously mentioned...Curb returns don't bog the software..close your Inventor before playing with Civil 3D..
Fred Ernst, PE
C3D 2027
Ernst Engineering
