I see two work around options:
1. Add a Note label style that includes reference text. The style can include a border and background mask. aa
- The reference text cannot address Profile Views, so you will have to link it to the Profile itself. The reference text component can use the Profile Name or Profile Description.
- The note label style can additional text "PROFILE FOR <[Name(CU)]>"
- Add the note label and position it over the Profile view.
(You may want to reposition or eliminate the actual profile view title.)
- This is dynamic to profile name/description changes.
2. Use 2 viewports. Divide and conquer. I assume that you will be publishing from a layout. (See sketch below.)
- Leave the Profile label title in its normal location below the profile view.
- On a layout, in paper space, create a viewport that includes the profile view but not the title
- On a layout, in paper space, create a viewport that includes just the title.
- Position the "title" viewport over the "profile view" viewport
- You may want to group the viewports.
- This is dynamic because you are using only the profile view and no supporting objects.
Both of these methods let you position the title to avoid profile view content.
It would de nice if the Civil 3D were to add background masks for the titles, or make more objects and properties available to reference text and fields. However, they seem not to address issues if there are work arounds, even if they are are obscure or cumbersome.
Christopher Stevens
