I've read two discussions that seem to address my question - but I still cannot figure out how to do what I want to do. I'm placing a swale parallel to a curb line for a parking area. I've graded the bottom of the swale up at a 3:1 slope around the entire bottom. I now want to tie in the feature line on one side of the swale to the back of the curb line - keeping the existing elevations along the curb line. I want to grade the rest of the perimeter of the swale to the exiting ground surface at a 5:1 slope. See figure below:
I've tried tracing the back of the curb with a polyline - then making the polyline a feature line (getting elevations from existing surface) and then adding the feature line to my swale surface as a non-destructive breakline. But then I'm stumped - how do I get a grading from my swale feature line to the new curb feature line? I've tried doing a 5:1 grade to surface along the entire swale feature line - but the grading doesn't stop at the new breakline.I can't do an infill between the swale and the curb since that area is not closed. I can grade most of the swale perimeter to the existing surface at a 5:1, but where do I start and stop - and how do I tie that portion of the swale surface into the part that will be between the swale and the curb? Thanks for any help.
Rick Jackson
Survey CAD Technician VI
Rick Jackson
Thanks. I did that, but it looks like I have to to something else as well. I traced the back of the curb with a polyline and then made that polyline an FL. I then added the FL to the surface as a non-destructive breakline. But ... when I check to see what's what with a quick profile I get the graph below.
You can see that the swale has been generated, but there is no surface between the swale and the curb line. How do I get the surface to extend from the swale to the FL that is the curb line?
Ok so you have a surface that is created from your grading, this surface should be a sepreate surface on a seperate site, and the FL tie at the BOC should also be on that site so as to not interact with your existing curb line. Just use a standard breakline, your creating a entirely new surface on a new site, by them being on seperate sites they wont interact with each other. and everything should tie in. (I just did a similar thing this weekend using points between an EG - FG sitiuation.)
Rick Jackson
Gotta love those surprises (Dam phone)
Rick Jackson
