Civil 3D Forum
grading slope
14 REPLIES 14
Message 1 of 15
garbageguy
2949 Views, 14 Replies
grading slope
when I create a grading by slope in C3D07, I get the same thing whether I give a slope of 3:1 or 1:3 - is that right?
14 REPLIES 14
Message 2 of 15
I think the program changes the value to match what is in the Edit Drawing Settings under slope, the program assumes you made a mistake since you told it you wanted to use it one way. If you want to have 0.33:1 you can use 3:9 and it will do the correct math.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 3 of 15
garbageguy
in reply to: garbageguy
the drawing's slope format is set to "run:rise", why won't 1:3 give me that slope?
Message 4 of 15
In my experience there is no need to type in the 1. For example, I would type a 3:1 slope in simply as 3. Seems to work every time.
Fred Mitchell
APAI
Message 5 of 15
Because that's the way it was programmed. If you want 1:3 you need to enter 0.33333 or 3:9 or 6:18 or some other numerical value. The program assumes you made a mistake and converts it to the way you have it in the settings if you use a 1:x value.
Civil Reminders
Message 6 of 15
in reply to: Civil3DReminders_com
which one is the horizontal or vertical?
Message 7 of 15
may you explain in a widey way,.... i want to know how it is (H:V) OR (V:H) AND THE (3) VALUE FOR WHICH ONE?
Message 8 of 15
Joe-Bouza
Hello @Anonymous
Call me silly they always meant the same to me
1 unit drop every 3 units
are you really looking to grade a slope
3 unit drop every 1 unit?
sounds like a wall is in order
Joe Bouza
Message 9 of 15
Joe-Bouza
Joe Bouza
Message 10 of 15
rl_jackson
Agreed, 2:1 is 2 for every 1, 4 to 1 the same... (and can be looked at in reverse based on situation). Soon we will have those rockets to mars.
Rick Jackson
Survey CAD Technician VI
Message 11 of 15
jmayo-EE
in reply to: rl_jackson
1:3
Isn't this convention rise over run?
Either way don't waste your time typing a full ratio. Just type 3 and hit enter if you want 1:3.
John Mayo
Message 12 of 15
fcernst
No, take a look at the Input Parameters in the Help for the subassemblies.
You will see the slopes need to be in run/rise or percent format.
If you give a daylight slope of 3:1 you will get a run/rise design slope of 3:1.
If you give a daylight slope of 1:3 you will get a run/rise design slope of 1:3
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
Message 13 of 15
Joe-Bouza
in reply to: jmayo-EE
exactly. ... that being said. aside from   1 run to 3 rise being impractical ... can the input even accept 0.33?
Joe Bouza
Message 14 of 15
jmayo-EE
in reply to: Joe-Bouza
Yes
John Mayo
Message 15 of 15
Joe-Bouza
there were two parameters in the question/statement (lol)
Joe Bouza
Rail Community
