grading slope
garbageguy
grading slope
garbageguy
when I create a grading by slope in C3D07, I get the same thing whether I give a slope of 3:1 or 1:3 - is that right?
Replies (14)
Civil3DReminders_com
I think the program changes the value to match what is in the Edit Drawing Settings under slope, the program assumes you made a mistake since you told it you wanted to use it one way. If you want to have 0.33:1 you can use 3:9 and it will do the correct math.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
garbageguy
the drawing's slope format is set to "run:rise", why won't 1:3 give me that slope?
In my experience there is no need to type in the 1. For example, I would type a 3:1 slope in simply as 3. Seems to work every time.
Fred Mitchell
APAI
Because that's the way it was programmed. If you want 1:3 you need to enter 0.33333 or 3:9 or 6:18 or some other numerical value. The program assumes you made a mistake and converts it to the way you have it in the settings if you use a 1:x value.
Civil Reminders
which one is the horizontal or vertical?
may you explain in a widey way,.... i want to know how it is (H:V) OR (V:H) AND THE (3) VALUE FOR WHICH ONE?
Joe-Bouza
Hello @Anonymous
Call me silly they always meant the same to me
1 unit drop every 3 units
are you really looking to grade a slope
3 unit drop every 1 unit?
sounds like a wall is in order
Joe Bouza
Joe-Bouza
Joe Bouza
rl_jackson
Agreed, 2:1 is 2 for every 1, 4 to 1 the same... (and can be looked at in reverse based on situation). Soon we will have those rockets to mars.
Rick Jackson
Survey CAD Technician VI
jmayo-EE
Isn't this convention rise over run?
Either way don't waste your time typing a full ratio. Just type 3 and hit enter if you want 1:3.
John Mayo
fcernst
No, take a look at the Input Parameters in the Help for the subassemblies.
You will see the slopes need to be in run/rise or percent format.
If you give a daylight slope of 3:1 you will get a run/rise design slope of 3:1.
If you give a daylight slope of 1:3 you will get a run/rise design slope of 1:3
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
Joe-Bouza
exactly. ... that being said. aside from   1 run to 3 rise being impractical ... can the input even accept 0.33?
Joe Bouza
jmayo-EE
Yes
John Mayo
Joe-Bouza
there were two parameters in the question/statement (lol)
Joe Bouza
