Grading Optimization Isn't Showing Up
jonathan
Message 1 of 12
jonathan
Hi, everyone.  I just installed Civil 3D 2025 and then installed the Grading Optimization package.  However, I can't seem to find it in my software.  It doesn't show up anywhere that I can see under the "analyze" tab, and the button on the home screen just takes me to the AutoDesk help area on how to download and install it (which I've already done).  Any ideas?  Thanks!
Replies (11)
Message 2 of 12
tcorey
Grading Optimization is part of your standard Civil 3D 2025. There are no separate files to install.
What you installed has to have been 2023 or 2022.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 12
jonathan
Well, that is frustrating.  There were no directions/directives, so it's not clear at all.  After purchasing AutoCAD it took me to a folder with "my products" (image below).  I did install the 2023 Grading Optimization package since it was in the list right beside AutoCAD Civil 3D.  Should I just uninstall AutoCAD 2025 and start over?
Thank you for your reply!
Message 4 of 12
muzmatt
Observer
Observer
I have the same issue. Did you come right in the end, if so how?
Message 5 of 12
Cadguru42
https://forums.autodesk.com/t5/civil-3d-forum/getting-c3d-2024-grading-optimization-not-easy/m-p/119...
See my post about how absurd Autodesk's UI design is, especially in regards to GO. Might help you to find the proper one.
C3D 2024-2026
Windows 11
32GB RAM
Message 6 of 12
jonathan
I never found the solution.  I assumed from the reply that there must be a simple solution I overlooked, but since I haven't had need to try grading optimization yet I didn't look into it any further (I was hoping someone might post something more!).  I'll take a look at your post, Cadguru, and see what it contains.  Hopefully I'll figure something out, and I'll post back here if I do.
I'm really shocked that no one from AuotDesk has chimed in.
Message 7 of 12
Cadguru42
Keep in mind that Grading Optimization isn't double-floating point precision. This means that if you want to grade something to elevation 500' it'll be between 499.95 and 500.05. It's a pain to use for actual plans because of this, but is great for getting a quick site plan.
C3D 2024-2026
Windows 11
32GB RAM
Message 8 of 12
ismael_amin_o
Community Visitor
Community Visitor
Hi! I have the same problem. Hope someone find the solution and post it. If I can make it work Ill let you know in comments.
Good luck!
Message 9 of 12
muzmatt
Observer
Observer
Hi All,
Worked it out. If you have C3D 2025 (or C3D 2024 I guess) then you need to download the grading optimization extension. To access this click on "View Details" below the download link for the product you are running and then go to extensions. See image below:
Message 10 of 12
Cadguru42
Yeah, that's what's in my post I linked to earlier.
https://forums.autodesk.com/t5/civil-3d-forum/grading-optimization-isn-t-showing-up/m-p/13377013/hig...
C3D 2024-2026
Windows 11
32GB RAM
Message 11 of 12
muzmatt
Observer
Observer
AHHH silly me - I had already sorted mine before seeing your link so I didn't actually check out your link! Sorry! but many thanks for the assistance! Keep well
Message 12 of 12
jonathan
Muzmatt--
I was going to post the same thing after trying the solution CadGuru posted.  It worked perfectly.  So, so confusing to see "Grading Optimization" under "my products" and that NOT being what you're supposed to install.  AutoDesk needs to do better.
Thanks to everyone for replying to my post!!
