Grading Optimization Error
jonmcdonald415
jonmcdonald415
I have used the GO feature in the 2022 install of Civil 3D. Since then we have moved on to C3D 2024 and I have installed the '24 GO extension. I just went to assign a closed polyline as a grading object and received this error. Any ideas?
brian.strandberg
This can be one of many issues, I have fixed this in the past with the registered tools path as explained in this document.  Don't do this if you are not familiar with editing the registry.
Take a look at this autodesk doc.
"Unable to execute the tool" when clicking any tool in the tool palettes in Autodesk Civil 3D
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
jonmcdonald415
I saw this doc and hoped getting into the registry wasn't the fix. There doesn't seem to be any documentation on uninstalling an AutoCAD extension either. I wonder if I could get a clean uninstall and reinstall it would work. Such a hassle defaulting the program and getting back profiles and customization IMO...
brian.strandberg
I would start by resetting settings to default, it's the least aggressive and may help.
