Civil 3D Forum
Grading building pad with crawl space!
6 REPLIES 6
Reza-WE
315 Views, 6 Replies
How do you grade a building pad with crawl space (2-4 ft height) in civil 3d when grading subdivisions.
Are you using grading groups or just feature lines as breaklines? I need to find the actual cut-fill volume after grading the crawl spaces.
When I use the grading group, the crawl space under the building pad is considered as Fill.
I've been searching for some resources explaining this type of grading but haven't found anything on the internet.
If you know of any video or website, please share.
Thank you all!
6 REPLIES 6
neilyj666
in reply to: Reza-WE
Not sure what a crawl space is - can you explain?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
LucasHicks
Joe-Bouza
in reply to: neilyj666
Shallow space under FFE; maybe be below grade but can be at eg
Joe Bouza
Joe-Bouza
Sounds like a job for DDTS
Joe Bouza
neilyj666
@Reza-WE Now I know what a crawl space is, are you using the finished floor levels to model the building pads? If this is the case I would adjust the levels to take account of the crawl space and would probably use featurelines (rather than grading objects) and add to a suitable surface to compute the cut/fill.
Reza-WE
Thank you @neilyj666 @Joe-Bouza @LucasHicks. Thanks all for your comments. I think that's the way to go (using feature lines instead of grading objects)
Rail Community
