Hallo C3D community, I made surface profile through alignment and sample line. In profile, I label grade breaks. Is it possible to put those points in situation, on sample line?
Regd
Solved by Jeew-m. Go to Solution.
Solved by AllenJessup. Go to Solution.
I don't have the program available right now. But I believe you have to modify your alignment labels to include the Profile Geometry.
Allen Jessup
CAD Manager - Designer
Dear Friend,
Profile geometry points can be drawn on alignment. Not on sample line. You can use following option for this.
Thx gents,
but the problem is that I have water stream (or corridor, or....) which is more then 6 km long, and have to do profile every 15-20m. Setting up sample lines on s alignment and set up profile "look " takes around 30 sec. If I have to do alignment for every profile, then set up surface profile, then set up that profile has to take data from specific surface...that will take much, much longer.
Thanks anyway,
Regd
