Google earth to C3D 2018
Message 1 of 17
Hi, guys, I just downloaded the Civil 3D 2018 and I cannot find where to insert a Google Earth image. Is it even possible or you can only insert from that other online map, the one which is in the program? I hope it's possible because I'm using the student version and the program says I have no permission for the Online Maps.
Replies (16)
Message 2 of 17
J.FOCHT
The Google Earth to Civil 3D feature was removed due to copyright issues back in 2013 edition.
There is a way to use Google Earth Explorer to download Ortho & DEM images for your specified area. Just do a google search for the explorer.
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
Message 3 of 17
Jeew-m
Message 4 of 17
KirkWM
Really? The student version doesn't allow the online maps? BING Maps is now built into C3D for free so that's what I'd try. You should just need an autodesk account and be signed in, then set the coordinate system and a new ribbon tab should immediatly appear called "Geolocation". If this does not happen you may need to get the hotfix as Bing updated their map services at some point: https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoc...
Hope this helps!
Message 5 of 17
Pointdump
D,
You're getting some good advice here. @Jeew-m 's recommendation of ArcGIS for AutoCAD is excellent. It will give you much better imagery than Bing Live Maps.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 6 of 17
KirkWM
Thanks Jeew-m this is really neat! Do you know if there's a way to print sheets using the Esri Maps World Map service? I was able to connect and now see the imagery in model space but it doesn't come though the paperspace viewports. Thanks.
Message 7 of 17
Pointdump
Kirk,
I noticed the same. When I selected one of my paper space tabs, the image goes bye bye.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 17
I have installed the ArcGIS, but I couldn't find the the .dll file anywhere, so basically I couldn't run it 😞1.png2.pngwinrar.png
Message 9 of 17
The hotfix worked, even though it said it's not supporting the version of the CD3 I am using.
Thank you all for the useful advices!
Message 10 of 17
Pointdump
D,
Did you run the EXE? It should automatically place the DLL here:
Dave Stoll
Las Vegas, Nevada
Message 11 of 17
Yes, I did, I even tried to do the repairing but nothing changed. Still no .dll files.
Thanks anyway!
Daria
Message 12 of 17
eng.ksoliman
I hope the following video help you.
Message 13 of 17
By default the layer 'ESRI_World_Imagery' is frozen in new VP freeze and VP freeze.
Message 14 of 17
mikeeddy15D95Z
You might look into Plex.Earth. I've had great experiences with it but it comes at a cost.
Message 15 of 17
Me too...
Plex.Earth comes with some cost but can do things you take it back 🙂
Message 16 of 17
mikeshick
Is ESRI free?
Mike Shick
www.medesigns.us
Message 17 of 17
rl_jackson
Negative! Probably more than C3D to be honest.
Rick Jackson
Survey CAD Technician VI
