I've added the GEOL_GEOL information but its still not coming in as it should (missing the descriptions and not showing the strata until changed to Legend Code. Below is the where I have added it. Any idea of the problem?
"GROUP","ABBR"
"HEADING","ABBR_HDNG","ABBR_CODE","ABBR_DESC","ABBR_LIST","FILE_FSET"
"UNIT","","","","",""
"TYPE","X","X","X","X","X"
"DATA","BKFL_LEG","902","Gravel backfill","",""
"DATA","BKFL_LEG","903","Bentonite backfill","",""
"DATA","BKFL_LEG","904","Grout backfill","",""
"DATA","BKFL_LEG","905","Arisings (cuttings) backfill","",""
"DATA","BKFL_LEG","906","Concrete backfill","",""
"DATA","DICT_STAT","OTHER","Other field","",""
"DATA","DICT_TYPE","HEADING","Flag to indicate definition is a HEADING","",""
"DATA","FLSH_TYPE","Air","Air","",""
"DATA","GEOL_LEG","101","TOPSOIL","",""
"DATA","GEOL_LEG","102","MADE GROUND","",""
"DATA","GEOL_LEG","103","Tarmac","",""
"DATA","GEOL_LEG","201","CLAY","",""
"DATA","GEOL_LEG","203","Sandy CLAY","",""
"DATA","GEOL_LEG","220","Sandy gravelly CLAY","",""
"DATA","GEOL_LEG","224","Sandy gravelly cobbly CLAY","",""
"DATA","GEOL_LEG","301","SILT","",""
"DATA","GEOL_LEG","303","Sandy SILT","",""
"DATA","GEOL_LEG","402","Clayey SAND","",""
"DATA","GEOL_LEG","403","Silty SAND","",""
"DATA","GEOL_LEG","404","Gravelly SAND","",""
"DATA","GEOL_LEG","410","Clayey gravelly SAND","",""
"DATA","GEOL_LEG","412","Silty gravelly SAND","",""
"DATA","GEOL_LEG","413","Silty gravelly cobbly SAND","",""
"DATA","GEOL_LEG","415","Gravelly cobbly SAND","",""
"DATA","GEOL_LEG","504","Sandy GRAVEL","",""
"DATA","GEOL_LEG","509","Clayey sandy GRAVEL","",""
"DATA","GEOL_LEG","528","Silty sandy cobbly GRAVEL","",""
"DATA","GEOL_LEG","801","MUDSTONE","",""
"DATA","GEOL_LEG","802","SILTSTONE","",""
"DATA","GEOL_LEG","803","SANDSTONE","",""
"DATA","GEOL_GEOL","TOPSOIL","TOPSOIL","",""
"DATA","GEOL_GEOL","MADE GROUND","MADE GROUND","",""
"DATA","GEOL_GEOL","Tarmac","Tarmac","",""
"DATA","GEOL_GEOL","CLAY","CLAY","",""
"DATA","GEOL_GEOL","Sandy CLAY","Sandy CLAY","",""
"DATA","GEOL_GEOL","Sandy gravelly CLAY","Sandy gravelly CLAY","",""
"DATA","GEOL_GEOL","Sandy gravelly cobbly CLA","Sandy gravelly cobbly CLAY","",""
"DATA","GEOL_GEOL","SILT","SILT","",""
"DATA","GEOL_GEOL","Sandy SILT","Sandy SILT","",""
"DATA","GEOL_GEOL","Clayey SAND","Clayey SAND","",""
"DATA","GEOL_GEOL","Silty SAND","Silty SAND","",""
"DATA","GEOL_GEOL","Gravelly SAND","Gravelly SAND","",""
"DATA","GEOL_GEOL","Clayey gravelly SAND","Clayey gravelly SAND","",""
"DATA","GEOL_GEOL","Silty gravelly SAND","Silty gravelly SAND","",""
"DATA","GEOL_GEOL","Silty gravelly cobbly SAND","Silty gravelly cobbly SAND","",""
"DATA","GEOL_GEOL","Gravelly cobbly SAN","Gravelly cobbly SAND","",""
"DATA","GEOL_GEOL","Sandy GRAVEL","Sandy GRAVEL","",""
"DATA","GEOL_GEOL","Clayey sandy GRAVEL","Clayey sandy GRAVEL","",""
"DATA","GEOL_GEOL","Silty sandy cobbly GRAVEL","Silty sandy cobbly GRAVEL","",""
"DATA","GEOL_GEOL","MUDSTONE","MUDSTONE","",""
"DATA","GEOL_GEOL","SILTSTONE","SILTSTONE","",""
"DATA","GEOL_GEOL","SANDSTONE","SANDSTONE","",""
"DATA","HDPH_TYPE","CP","Cable percussion (shell and auger)","",""
"DATA","HDPH_TYPE","IP","Inspection pit","",""
"DATA","HDPH_TYPE","RC","Rotary cored","",""
"DATA","HDPH_TYPE","RO","Rotary open hole","",""
"DATA","HDPH_TYPE","WS","Window Sampler","",""
"DATA","ISPT_TYPE","C","Cone","",""
"DATA","ISPT_TYPE","S","Split spoon","",""
"DATA","LOCA_TYPE","COM","Competitor","",""
"DATA","LOCA_TYPE","CP","Cable percussion (shell and auger)","",""
"DATA","LOCA_TYPE","IP","Inspection pit","",""
"DATA","LOCA_TYPE","RC","Rotary cored","",""
"DATA","LOCA_TYPE","RO","Rotary open hole","",""
"DATA","MOND_TYPE","DSTL","Distance","",""
"DATA","MONG_TYPE","SP","Standpipe","",""
"DATA","PIPE_TYPE","PLAIN","Plain","",""
"DATA","PIPE_TYPE","SLOTTED","Slotted","",""
"DATA","SAMP_TYPE","B","Bulk disturbed sample","",""
"DATA","SAMP_TYPE","ET","Environmental tub","",""
"DATA","SAMP_TYPE","T","Small disturbed sample (Tub)","",""
"DATA","SAMP_TYPE","U","Undisturbed sample - open drive","",""
"DATA","SAMP_TYPE","V","Vial sample","",""
"DATA","SAMP_TYPE","W","Water sample","",""
