Geolocation Problem
Geolocation Problem
Geolocation Problem
Since Jun 2016, when Autodesk released a Hotfix to update the database imagery, GEOLOCATION does'nt work properly. But now Autodesk announced the RETIREMENT of A360 Desktop. If you try to use Geolocation come up a screen requesting the assinment on A360! It means that GEOLOCATION Is not available anymore?
MMcCall402
You didn't mention what windows version you're running, civil 3d version and if it has all the service packs and such.
Also, have you tried any of the methods in the following post. The loginstate.xml usually fixes our stations when they go wonky.
https://forums.autodesk.com/t5/civil-3d-forum/civil3d-geolocation/m-p/6839531
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Thank you for your suggestion. The sign in / sign out solution works
properly
