Geolocation Aerial map not working Civil 3D 2017
ArthurADas
ArthurADas
I'm using civil 3D 2017, and i'm trying to open the aerial map in a Infraworks exported file, but the image doesnt show up. I swear i tried every single solution that i found here, but none of them worked.
What i'm doing is:
On Infraworks: Generate a model > Find a plce > Export imx file > Choose an area
On Civil 3D: Insert tab > On infraworks icon > Open infrawork model. Then, when the surface is there i try to turn the aerial map but when i change nothing happens. The ''BING'' logo is showing, but that's the only thing that display.
Solutions that i already tried: Reinstall all autodesk apps
- Sign out and in on my civil 3d account on civil 3D software
- Sign out and in on my accounts on browser related to autodesk
- Cleaned my internet info
- Reinstall only A360
- Turn on the hardware acceleration
- Install the Hotfix
I'm attaching a screenshot.
Replies (32)
Pointdump
Arthur,
OK, from QGIS(You can open ANYTHING in QGIS) I exported a CSV file of the Existing Ground Points in <<<EPSG 32723>>> Coordinates. Drag-n-Drop the attached Shapefile into a Blank drawing and you'll be able to turn on Bing Live Maps. So I think the disconnect is with InfraWorks-to-C3D Workflow. (Maybe)
I'm going right now to watch your linked video.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
ArthurADas
Dave,
Thanks for the help, but i've never used Coordinates with points before, i always got the surface ready with contours from Infraworks.
About the file, i dropped in a black drawing just as u said, the points showed up but the Geolocation Tab didnt display. And what do i do with those points? They can create a surface with elevations by doing something?
Pointdump
Arthur,
OK, now we're getting somewhere. After Drag-n-Dropping that Shapefile into a blank drawing, you should be able to turn on Bing Live Maps and see this:
Since you don't, the problem is with Bing Live Maps.
As for the CSV Points, those become Map Features when you Drag-n-Drop them. (Same as _MAPCONNECT). To create a Surface, you add that included CSV file to your Surface Definition.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
As a thoroughly unrelated observation, when Jeff added that tree in InfraWorks, I immediately wondered if you could add a 20-story tall Godzilla.Smiley Very Happy
Dave
Dave Stoll
Las Vegas, Nevada
WarrenGeissler
@Pointdump and @ArthurADas,
After Dave hit on the units setting in Civil 3D I did a little more digging. For some goofy reason, you must assign your coordinate system BEFORE you import your IMX file.
1. Start new drawing with METRIC template (Using the wrong template and changing the Civil 3D units afterwards confuses the poor little program)
2. It you do NOT know the CS of the incoming IMX file, begin to attach it - write down the CS and CANCEL.
3. Type MAPCSASSIGN - type in the CS from the IMX file
4. Attach the IMX file
5. Turn on BING maps - everything works
I have the feeling that the acceptance of the Infraworks CS directly into C3D is a little messed p.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Pointdump
Warren,
"Start new drawing with METRIC template (Using the wrong template and changing the Civil 3D units afterwards confuses the poor little program)"
Yup. Here's what happens when you _MAPCSASSIGN the UTM84-23S Coordinate System to an Imperial (Feet) Drawing:
Dave
Dave Stoll
Las Vegas, Nevada
ArthurADas
''As a thoroughly unrelated observation, when Jeff added that tree in InfraWorks , I immediately wondered if you could add a 20-story tall Godzilla.Smiley Very Happy''
hahaha maybe you can
ArthurADas
I'm trying your suggestion, but i'm stuck in the ''Type MAPCSASSIGN - type in the CS from the IMX file'' part, where is this CS from the IMX?
WarrenGeissler
When you use the Open Infraworks Model command the coordinate system will be at the top of the dialog box (in this case it was UTM84-23S).
Then Cancel that dialog - and in Civil 3D at the command line type the command "MAPCSASSIGN". In the SEARCH window - type the CS you found (Again, in this case it was UTM84-23S)
Warren Geissler
ArthurADas
Sorry for the following words.
Oh my ****IN GOD, IT is FINALLY WORKING, THE MAP IS THERE NOW
OMGGGG, thank You so much guys, i was getting super mad here ready to give up on this project, but it is finally working.
Thanks again
Pointdump
Arthur,
I tried to add one of these attached Sketchup Godzillas to a Sample InfraWorks Model, but was unable to make him "stick" in the model.
Dave
Dave Stoll
Las Vegas, Nevada
WarrenGeissler
Dave, that's freakin' AWESOME Smiley Very Happy
Warren Geissler
ArthurADas
Wow, that's even possible? Smiley Surprised hahahahaa very nice
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
