Frequency subassembly composer
RonaldBrañez
RonaldBrañez
Can we define the frequency of section creation from an input parameter in SAC using the baseline APIs or other parameters?
Yonas89
Not from the input parameter. Frequency belongs to corridor object, and at the center frequency you place you assemblies. You cannot send such information from bottom object (assembly) to top object (corridor).
RonaldBrañez
I was referring to creating an input or output parameter in SAC. Indeed it cannot.
I found the answer in another post. Anyway thanks for the reply.
