Civil 3D Forum
Forgotten Command
5 REPLIES 5
Brent_EliasonZP5YT
351 Views, 5 Replies
Forgotten Command
I have forgotten the command that we use to bring up the dialogue box to alter / change the default layers in Civil 3D operations. Not the 'Settings' in the tool space.
Screen shot attached. If "0" is the default, what is the command to change this for every new drawing, without having to click the layer button next to it constantly?
Cheers
Labels (1)
5 REPLIES 5
Command DRAWINGSETTINGS, tab Object Layers:
It is saved in the drawing, so saving it as a template, it will be applied in new drawings based on this template.
Set the current layer in your dwt file
Joe Bouza
You can also modify that on the Settings tab under the command settings for Alignments
Rick Jackson
Survey CAD Technician VI
user181
in reply to: Anton_Huizinga
The command is EDITDRAWINGSETTINGS
Awesome!! Thank you. I appreciate your help.
Take care.
brent
Rail Community
