Civil 3D Forum
Fire Hydrant with "S" Type Elbow
2 REPLIES 2
jawed.sheikh
347 Views, 2 Replies
Good Day Folks,
I am trying to draw this S type elbow in Potable Water Pressure Network Plan, From Main line There is Tee then Pipe then Valve and then Fire Hydrant, Its easy but I am stuck to add these 2 Elbows at Plan, Any Quick and Easiest way to add those elbows to make my life easy. Your early response will highly Appreciated.
Thank You
Jawed
2 REPLIES 2
Olga-L
in reply to: jawed.sheikh
Hi Jawed,
I tried to do it from Plan, with no success. My method is not perfect, but it works fine for most cases:
  • put pipe (short one) and Hydrant at plan, still no elbows; isolate them
  • go to any isometric 3d view
  • starting from the hydrant end, add all the needed connecting parts using pipe snapping
Hope it will help,
Olga Lukashevsky
BIM Manager
jawed.sheikh
in reply to: Olga-L
Hi Olga,
Hope you are doing good, Thanks for your feedback. I found a tricky way to create this type of 90 degree bend and got success. I used a 3dline and add vertex of different elevation and run the pressure network and I got my S elbow. I am going to share my 3d line for  your understanding.
Jawed
Rail Community
