Good Day Folks,
I am trying to draw this S type elbow in Potable Water Pressure Network Plan, From Main line There is Tee then Pipe then Valve and then Fire Hydrant, Its easy but I am stuck to add these 2 Elbows at Plan, Any Quick and Easiest way to add those elbows to make my life easy. Your early response will highly Appreciated.
Thank You
Jawed
Solved by jawed.sheikh. Go to Solution.
Hi Jawed,
I tried to do it from Plan, with no success. My method is not perfect, but it works fine for most cases:
Hope it will help,
Olga Lukashevsky
BIM Manager
Hi Olga,
Hope you are doing good, Thanks for your feedback. I found a tricky way to create this type of 90 degree bend and got success. I used a 3dline and add vertex of different elevation and run the pressure network and I got my S elbow. I am going to share my 3d line for your understanding.
Jawed
