Fillet goes the wrong way
jbear0000
Message 1 of 45
jbear0000
I've been having a problem with the fillet command. When trying to fillet a polyline it often puts the curve in going the wrong way, see the attached images.
When I try to fillet with a 40' radius it works fine, but when I try to do a 35' radius or smaller it does it wrong.
UCS is set to world
I ran flatten on the polyline
I tried to reverse the polyline
I exploded it and joined it back together
Fillet trim mode is set to trim
None of that helped, it keeps doing this. Depending on where I click on the line it flips a different way, but won't do it correctly no matter where I click. If I explode it then it does it correctly, but I shouldn't have to explode every polyline in order to get the correct arc.
I'm using Civil 3D 2016 SP1.
Replies (44)
Message 2 of 45
Patchy
Message 3 of 45
jbear0000
I guess you didn't read my entire post, particularly the part that said "I tried to reverse the polyline"
Message 4 of 45
pendean
Community Legend
Community Legend
Pretty pictures: how about a DWG file and point to the two points you picked in the file so we can do wat you are doing. Thanks.
Message 5 of 45
jbear0000
Here is a dwg file, just click anywhere and try using a 35' radius and you will see what it is doing.
Message 6 of 45
It's probably because one of your PL segments is an arc.
Message 7 of 45
pendean
Community Legend
Community Legend
Like Jason said...
Message 8 of 45
jbear0000
I know it is an arc, it needs to be, but it still shouldn't be doing the curve backwards. It works fine with a 40' radius, it works fine with a line and an arc, but not as a polyline and a 35' radius. Try it. So, why does it work with a 40' radius and not a 35' radius? If it was just the fact that it is a curve it would do it with both.
Message 9 of 45
I broke the fillet at the intersection, tried to fillet it again and it work. Still don't understand why it wasn't working to begin with.
Message 10 of 45
There's always more than one way to skin a cat in AutoCAD, I would've drawn a circle using tangent tangent radius and trimmed the polylines, joined and moved on...
Message 11 of 45
Pointdump
J,
Have you tried turning off High Quality Geometry?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 12 of 45
jbear0000
Yes, I know, but when using Autoturn and having a truck turning template attached to that polyline and having to recreate it every single time I want to try a different radius takes much more time than just using the fillet command and expecting it to work the way it is designed to work.
Message 13 of 45
jbear0000
I already have that turned off.
Message 14 of 45
tcorey
Did you try it as an alignment? Will AutoTurn use a Civil 3D alignment? Autodesk Vehicle Tracking will. (I had to get that plug in there!)
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 15 of 45
Pointdump
J,
I'm not able to re-produce the problem. Recommend you update your service packs.
Dave
Dave Stoll
Las Vegas, Nevada
Message 16 of 45
Timothy_Sean_Hulbert
Greetings,
Thank you for your recent forum post.  My name is Sean and I am more than happy to help you with this issue. I see from the thread that other members of the community have been working with you on this issue regarding your fillet going the wrong way on a polyline. I have seen this before, and generally explode the polyline as a work-around. I do realize how annoying that can be. Would you mind sharing the drawing?
I have subscribed to the thread though and will continue to monitor it should you need additional assistance. If you would like to communicate directly, you may do so at any time by sending me a private message in the forum.
Timothy "Sean" Hulbert, PE
Product Support Specialist
Link Name | Link Name | Link Name | Link Name
Message 17 of 45
jmayo-EE
Explode first. Join after fillet.
You should not be able to fillet an arc and line segment within a pline. I don't know why ur file allows that without getting the 'Cannot fillet between these two entities.' error at the command line...
Fillet between line and arc is permitted but not with in a pline.
John Mayo
PE, CFM, CME
alt="EESignature" width="244" height="22">
Message 18 of 45
jbear0000
Here is the dwg file with the lines that were giving me trouble.
Message 19 of 45
jbear0000
It wasn't a polyline and an arc, it was 2 polylines. Exploding it is a poor solution. Especially if the polyline is very long, has a width, perhaps dimensions or hatch associated to it or has Civil 3D labels associated to it. All of that would be messed up by exploding it.
Message 20 of 45
Pointdump
J,
"...just click anywhere and try using a 35' radius and you will see what it is doing."
"It wasn't a polyline and an arc, it was 2 polylines."
Sorry, I'm just not seeing the problem. I see A polyline, and as @Anonymous says, "Fillet between line and arc is permitted but not within a pline."
I've even tried drawing some polylines and filleting between them with different radii. Can you post a drawing with ONLY the two polylines that the problem shows up in?
Dave
Dave Stoll
Las Vegas, Nevada
