File Problem
File Problem
Message 1 of 11
File Problem
I am having problems getting a file to open. Wondering if anyone has had this message come up that I have included. I have the newest version of CAD so I'm not sure why it would be saying this.File S.PNG
Replies (10)
Message 2 of 11
Todd_Rogers
  1. In command line, type QSELECT
  2. In the Quick Select dialog box, set Apply to Entire Drawing, Object Type to ACAD_PROXY_ENTITY and set Operator to Select All (this will select all proxy objects)
  3. In command line, type E (E stands for erase,) and then hit enter (this will erase all proxy objects you selected).
  4. PURGE and AUDIT drawing.
  5. Save drawing and close it.
  6. Open drawing and if the same message appears repeat all steps until the message disappears.
Todd Rogers
Civil Administration
Message 3 of 11
It does not give me the option of ACAD_PROXY_ENTITY??
Message 4 of 11
jmayo-EE
This is a warning not an error unless you click OK and the file doesn't open. If it opens just do your work.
If you don't want to see it every time you open make sure Civil 3D is fully updated. Update 2019.2 was released not long ago. If your system has all updates and you still receive this you may want to open a support case.
John Mayo
PE, CFM, CME
alt="EESignature" width="244" height="22">
Message 5 of 11
It will Open but like it says it is disabled it will not let me make any
changes.
Message 6 of 11
jmayo-EE
Updates?
John Mayo
PE, CFM, CME
Message 7 of 11
Yes my software is up to date we just installed all new.
Message 8 of 11
Jeew-m
Hi tyler.wilsonB3EUQ,
Autodesk very recently released an update for Civil 3D 2019. Have you installed it.
https://forums.autodesk.com/t5/civil-3d-forum/autodesk-civil-3d-2019-2-update/td-p/8453088
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 9 of 11
Yes I believe I have the latest one. We just updated this morning.
Message 10 of 11
Jeew-m
After this patch is applied successfully, the product version specified in the About dialog box will be 13.0.1175.0
Is this the version you have after update.?
Jeewana Meegahage
Design Engineer
Message 11 of 11
Yes that is what I have.
