Civil 3D 2019.2 Update is now available for download. You can obtain this in your account page or through the Autodesk Desktop App.
Autodesk® Civil 3D® 2019.2 Update provides a combination of extended tools for railway design, new collaboration tools, and general design, quality, and production efficiency enhancements for Autodesk Civil 3D 2019 users. With this update, transparent commands are now accessible using the right-click menu, a new ribbon and a contextual ribbon tab. Data shortcut projects now support using a UNC path. Sample line group support has been added to Autodesk® Vault®. LandXML now has property set support for all objects and existing objects are updated on re-import. This update includes other new functionality, as well as general improvements that will benefit all Autodesk® Civil 3D® 2019 users.
Important Note:
The Autodesk® AutoCAD® 2019.1.2 Update is a prerequisite of the Autodesk® Civil 3D® 2019.2 Update and must be applied prior to installing the update. If applying the update through the Autodesk Desktop App all prerequisite updates will automatically be installed.
You can apply this update to the following Autodesk products running on all supported operating systems and languages. Be sure to install the correct update for your software.
After this patch is applied successfully, the product version specified in the About dialog box will be 13.0.1175.0.
