- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
What am I missing here? I have a corridor data referenced into another drawing and I want to change the display of the feature lines in it. I don't want to go into the corridor properties and manually change the feature line styles so I change the styles in the code set style. Problem is, it doesn't change the corridor because it already has the codes assigned to the feature lines in the feature line tab of the corridor properties. Synchronizing the corridor doesn't help. Only solution I've found is to open the drawing with the corridor in it, Turn off all regions in the corridor properties, save the drawing, synchronize the corridor, go back to the original drawing, turn on all the regions, save the drawing, and synchronize again.
Seriously, what am I missing?
