Feature line PI question...
Jerry_Barnes
Message 1 of 12
Jerry_Barnes
In the attached screen shot of the feature line elevation editor, there are PIs that are clear (vs. a green interior shade) that are not editable. What are these points, exactly? These PIs have no crossing or attached feature lines.
Replies (11)
Message 2 of 12
Jeff_M
Are they crossing ParcelLines in the same Site? Featurelines interact with those as well as other featurelines.
Message 3 of 12
Mike.M.Carlson
Like @Jeff_M indicated, if your feature line was created based on a "Site" and it is overlapping another Site object, the FL will add the intersecting vertex so the two are coincident. To remove this behavior, you can select the feature Line, and under the contextual ribbon look for Move to Site command and choose Site "None". Then try Elevation Editor again and those extra vertexes will disappear.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Message 4 of 12
Neilw_05
I've seen gradings cause vertices like that where they transition from cut to fill.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 5 of 12
BrianHailey
Definitely a site issue. Your featurelines are crossing other features that are in the same site. Here's an article I wrote about it a while back: https://civil3dplus.wordpress.com/2010/09/06/when-a-site-isnt-a-site/
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 6 of 12
Jerry_Barnes
The feature line is not crossing any other feature lines, and no parcel lines exist in the drawing. Based on a solution I found in another similar forum question, I changed the feature line style to another style and voila! The PIs were suddenly normal PIs in the PI editor. I switched the style back to the original style and they went back to zombie PIs. Switched back to the new style, and normal PIs they became. (<-A nod to Yoda.) So... go figure.
Message 7 of 12
Neilw_05
While you found a solution by changing the style, I am curious: have you checked if there are 2 featurelines stacked on top of each other?
WIN 10 64 PRO
Message 8 of 12
fcernst
That’s Style prioritization hierarchy.. in Site properties
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
Message 9 of 12
Jerry_Barnes
I had never heard of style prioritization before. I found it in site properties as you mentioned. Not clear on how that works. Can you elucidate for us, please? Remember, there are no crossing feature lines, if that makes a difference.
Message 10 of 12
Jerry_Barnes
Neil, I double-checked if there were double feature lines on top of each other and there were not.
Message 11 of 12
Neilw_05
Have you run audit and recover? All layers on and thawed? It sure acts like stacked featurelines. I'll bet if you move it to another site the behavior stops.
WIN 10 64 PRO
Message 12 of 12
BrianHailey
Post up a sample file showing the issue so we're better able to assist. I still think it's a site issue.
GEI Consultants
My Civil 3D Blog
