Feature Line Data Export to Table with Area
klantzZS7E7
Message 1 of 10
klantzZS7E7
I've used feature lines to create wetland tops and bottoms for layout and grading purposes. I'm trying to get a table with Name/ID, Layer name, min/max elevations, and area. I've tried using Data Extraction, SHP import/export tool, mapexport, and Dynamo (I'm very new to Dynamo but I didn't see "get area" in the Civil 3D tool kit package options for feature lines). Data extraction is the only thing that I can find that will export the area, but it doesn't include the name/ID. I've assigned the wetland ID in the "Name" field (using apply feature line names), also added a property set for ID and added object data. I only tried the property set ID and object data on a small subset to see if they would show up. None of those are working. I did find that I can add a name in the description field as a work around; however, I have around 300 different lines so it's a lot of work to add the info into the description of all the lines. Since I already have the name field populated I was hoping to avoid manually entering it. Any advice? Thanks!
Replies (9)
Message 2 of 10
Erica407Den
Community Visitor
Community Visitor
Hello!
To extract feature line data in Civil 3D, use Project Explorer (if available) for a structured report, or copy data from the Elevation Editor into Excel. Property sets should be correctly linked before exporting, and while Dynamo lacks a built-in "get area" function, a custom script may help. If needed, combining Data Extraction with manual refinements in Excel could be the most efficient approach.
Best Regards,
Erica
dog language translator app
Message 3 of 10
nkiakas
Hi @klantzZS7E7
This one sounds like common Dynamo for C3D workflow.
Regards
Message 4 of 10
nkiakas
Hi @klantzZS7E7
You can do something like the attached
Regards
Message 5 of 10
klantzZS7E7
Thank so much, nkiakas! This looks like it will work great, but I can't find the create table by data node (2025 or 2026). Is this in an add-on package? I'm new to Dynamo and have lots of learning to do.
Message 6 of 10
nkiakas
Hi @klantzZS7E7
Yes you have to install the package "The Civil Nodes" to dynamo (its free).
You can do it with the package manager inside dynamo for C3D.
Regards
Message 7 of 10
Gil_C
I would definitely start with a Project Explorer file export. Good chance that will do the trick.
Gil Cordle
Digital Design Manager | Technology Consultant | Autodesk Expert Elite | AUGI Board of Directors | CITE User Group Leader
@GilCordle on LinkedIn | @GilCordle on X | @GilCordle on YouTube
Message 8 of 10
klantzZS7E7
Thanks, All! I was able to get the data I needed with Nkiakas's solution. I also used the Excel export option when I couldn't find the table node. I'll look into Project Explorer file export; I haven't used that.
Message 9 of 10
klantzZS7E7
Quick follow up, Project Explorer does not include an option for Feature Line Area either. Otherwise, it looks like it would have worked well!
Message 10 of 10
jkoehn_tindol
Community Visitor
Community Visitor
You. Are. The. Man.
