- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've used feature lines to create wetland tops and bottoms for layout and grading purposes. I'm trying to get a table with Name/ID, Layer name, min/max elevations, and area. I've tried using Data Extraction, SHP import/export tool, mapexport, and Dynamo (I'm very new to Dynamo but I didn't see "get area" in the Civil 3D tool kit package options for feature lines). Data extraction is the only thing that I can find that will export the area, but it doesn't include the name/ID. I've assigned the wetland ID in the "Name" field (using apply feature line names), also added a property set for ID and added object data. I only tried the property set ID and object data on a small subset to see if they would show up. None of those are working. I did find that I can add a name in the description field as a work around; however, I have around 300 different lines so it's a lot of work to add the info into the description of all the lines. Since I already have the name field populated I was hoping to avoid manually entering it. Any advice? Thanks!
