Extract Cut Boundary from volume Triangulation Surface
neilyj666
Mentor Mentor
neilyj666
I want to extract the cut limits from a volume surface i.e. the "0" level as an enclosed shape so I can do some GIS type analysis but it is proving very frustrating.
I have tried exploding the surface and shrinkwrapping the resulting solids but this causes a shift in X/Y for some reason.  I've also tried extracting the zero contour and surface boundary to create the areas but this also fails due to not closed boundary errors
There must surely be an easy way to do this so please hit me up with some suggestions
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
tcorey
If I was doing this, I would create a user contour at 0, then extract from surface: User Contours and Surface Border.
That will give you polylines you can manipulate into a closed entity. You will need to join the polylines into a single object.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
neilyj666
At the moment I am doing just this although I used the minimum dist between surfaces rather than the zero contour.
It is extremely frustrating that the surface analysis shows the area I want but it cannot be extracted easily and I have to manipulate polylines to get the closed boundaries
neilyj666
I went back to the first method and FLATTENed the solids and the shrinkwrap boundaries were created as expected
