Civil 3D Forum
Expression for displaying difference in elevation
4 REPLIES 4
520 Views, 4 Replies
I am tried doing a search through the forum and also online.
I'm currently trying to understand the process to create a label which displays the difference in elevation between two cogo points. I've tried it a couple of different ways with both a line between the two points and using the points themselves.
I'm sure this question has been asked before but I feel that I'm not asking the question properly so my results aren't tailored to what I need.
Any suggestions?
4 REPLIES 4
AllenJessup
I don't think I've seen this asked before. I don't know of a way to do specifically what you're asking. Usually when the difference in elevation is needed it's between 2 Surfaces. For that you create a Volume Surface and label that Surface. You could use that method and label at the point where you're 2 cogo points overlap.
Allen
Allen Jessup
CAD Manager - Designer
jmayo-EE
You can use a line label with an expression to get the dwlta z on any line segement. THis will not work from start to end on a nmultisegment 3dpoly, feature line or figure. It only works on a 3d line or any single segement of a feature line or figure. The ABS (absolute value function is optional. ABS({General Segment End Z}-{General Segment Start Z})
John Mayo
AllenJessup
I knew the method John mentioned (because he taught me) but I didn't know the Expression. One thing to mention is that if the points aren't directly over each other is to create the line or Featureline on a NoPlot layer or use a non-plotting color.
Allen
Allen Jessup
in reply to: jmayo-EE
Jmayo,
This sounds like a solution which will work. I am not using a surface because building the surface will take alot more time and won't benefit us in any other situation. Using point to point (or start and end of line) is ideal due to the number of points which all vary.
My understanding is that this expression should fall under: settings-> general->label styles->line ?
Thanks to jmayo and AllenJessup for looking at this.
P.
Rail Community
