Exporting points points to a CSV file error
D_Bynum
Message 1 of 15
D_Bynum
When exporting points to a CSV file, the attributes in column (F) are over-writing existing attributes in column (K). This just recently started and not sure what is causing this to happen. Any suggestions?
Replies (14)
Message 2 of 15
Pointdump
More information please.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 15
D_Bynum
More info like what?
Don't know what else to say other than after inserting a CSV file into a DWG and then exporting the points out to a new CSV file,  the attributes in column "F" are duplicating themselves (some cases, over-writing existing data) in column "K".
Message 4 of 15
Pointdump
Dan,
Please post your drawing and the original CSV file. Another set of eyes on your UDP and Point File Format might catch something you missed.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 15
ChicagoLooper
@D_Bynum wrote:
When exporting points to a CSV file.............
If you want a csv file you can simply copy the point info. Right click All Points and select Edit Points. (Image-1)
1-Right click All Points.1-Right click All Points.
The PANORAMA will appear. Highlight all rows so they're blue, right click then select Copy to Clipboard. (Image-2)
2-Highlight all rows, right click, then copy to clipboard.2-Highlight all rows, right click, then copy to clipboard.
Open a blank spreadsheet, highlight cell A1, right click and select PASTE. The clipboard contents will appear in THEIR respective rows and columns. Perform a SAVE AS in csv format.
Chicagolooper
Message 6 of 15
AllenJessup
There are many formats of CSV files. The most common is PNEZD and the longest OOTB. You mention column F and K
PNEZD
ABCDEFGHIJK
You must have a lot of user data or other fields. Anyone trying to help will have to see what kind of data you have and how you've set up the CSV file format for export.
Allen Jessup
CAD Manager - Designer
Message 7 of 15
cwr-pae
What @AllenJessup , @ChicagoLooper  and @Pointdump say. Plus, I see reference to this issue when people add new classifications to the "unclassified" set instead of creating their own new set.
Message 8 of 15
lynn_zhang
Hello @D_Bynum ,
Just checking to see if your problem has been solved. Did the response from our experts above help answer your question? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Message 9 of 15
D_Bynum
importing points
'insert' ribbon tab / 'points from file'
or
'importpoints' command line
exporting points
'output' ribbon tab / 'export points'
or
'exportpoints' command line
compare:
imported point file
exported point file
has you can see, column "F" info is overwriting column "K"
csv files and dwg attached.
Message 10 of 15
Pointdump
Dan,
Thanks for posting your drawing and data.
Here's what I see. In your "As Built-ACMP" Point File Format I didn't see any of your "CHKM" User-Defined Property Classifications. When I added them to a "As Built-ACMP_2" Point File Format, all the classifications seem to slot themselves in correctly. Please check the attached drawing and CSV files.
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 15
D_Bynum
can not open your attached DWG - newer version. I am using Civil 2017.
Message 12 of 15
Pointdump
Dan,
Sorry about that. Unfortunately, I don't have 2017. Please check this attached "EXPORTED_2" CSV file to see if the Export worked from my drawing. And please post a Screen Shot of your "As Built-ACMP" Point File Format. I'm wondering if there are version-specific problems with Point File Formats.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 15
D_Bynum
the file looked ok, except for missing columns 'L,M & N'.
point file format
Message 14 of 15
Pointdump
Dan,
I didn't notice those missing columns. OK, so to get L,M, and N you would need to add "ATT7","ATT8", and "ATT9" to your CHKM User-Defined Property Classifications and then add all of those ATT1-9 UDP's to your Point File Format.(Replace those <unused> columns.)
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 15
lynn_zhang
Hello @D_Bynum
Just checking to see if you're still having the problem. Did the response from @Pointdump help solve your problem? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
