Exporting Earthwork Plan Production Data to Tabular or Excel format.
Dear All,
Can someone suggest how do I export the Earthwork Plan Production Data to Tabular or Excel format?
Thanks in advance for your suggestings and Ideas.
Best Regards,
Vijay Kumar.
samir_rezk
Hi @vijaykumar.kote
I am not sure which data specifically that you need to export to a spreadsheet, but you can use the AutoCAD Data Extraction command to extract the text box Value, Layer and Location and then perform some clean up on the data in Excel. You would be able to sort the data by the X location (i.e. by Column) or Y Location (i.e. by Row)
I made a short screencast video to demonstrate the workflow.
hope this helps,
Samir Rezk
Technical Support Specialist
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Have you tried the above suggestion from @samir_rezk and did it work for you? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
