Hi All
I've recently moved from C3D 15 to 16 and noticed how when I exported a to a CAD drawing the various edge of road levels etc maintained their 3d entities. This was a welcome addition from 15. I've now moved to 2017 and found that it has reverted to exporting to an autocad drawing and losing its 3d entities. With alot of the work I carry out the contractor wants a dwg or dxf as an output with the 3d polylines or polylines with z values.
Am I missing something or is there an easy straight forward way to do this? At the moment I'm having to extract 3d polylines from each feature line!!! this is very slow and time consuming. I do not understand why you cannot just export from Civil3D to Autocad while maintaining the 3D entities, that is why I'm hoping that im missing something
Thanks in advance
Shay
Solved by Karsten.Saenger. Go to Solution.
Thank you
I'm still confused but have put my query in that thread
thank you
Shay
Hi @Anonymous
in Civil 3D 2017 the solution is to Extract the Feature Lines from the corridor first (FEATURELINESFROMCORRIDOR). With the option ALL you are able to extract all corridor feature lines in one go.
The function was available in Version 2016 already, but without the "All" option.
Karsten.
