Export points from cross sections to a spreadsheet
cadmate_
cadmate_
Hi Civil 3D team,
Can I able to export the points on cross sections on a spreadsheet? If you know something about it or have any other alternative solution please feel to share. Cheers
stevenh0616
Hi @cadmate_
There is not a way to do this out of the box. Essentially, you'd need a way to generate points of a specific Section (veritcal section), in plan view, along the sample line. From there you would then export the points - but this does not exist out of the box. It could be done in .NET or even perhaps Dynamo, but it would take a bit of effort.
Alternatively, perhaps Section Reports would get you what you need? This would be coming from the Corridor, assuming you have a corridor.
If you are running Sample Lines from surface data along (ie from just a few survey'd surfaces) then there is not a way to do this without custom development of some sort.
Perhaps a suggestion on the Civil 3D Idea Station would be beneficial.
https://forums.autodesk.com/t5/civil-3d-ideas/idb-p/31
Steve Hill, Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
stevenh0616
Follow up - It looks like Project Explorer has some ability to do what you're after, but appears to only be one section/sample line at a time and not all at once. You can copy/paste the grid of data into Excel.
cadmate_
Thanks @stevenh0616 for the reply. In this endeavor, I refrain from establishing corridors solely for the purpose of generating elevations for slope stability analysis software. Instead, I have employed the following methodological steps to procure elevation data and seamlessly integrate it into a spreadsheet format.
