Hi everyone! I´m trying to export the corridor from Civil 3d to 3d max, but, when i use the Export to CivilView the corridors are not available to be selected. Anybody have a tip to solve this issue?
Thanks!
*Title edited from: Export corridors CivilView
Solved by hagen.deloss. Go to Solution.
Hi @projetosRR8RU,
Appreciate you bringing your question to the forums! This might be more of a question for the Civil 3D forums here, but i did find this older workflow video on the 3ds Max learning channel that might help you prep your civil project to import into 3ds Max.
@lim.wendy have you had any experience in exporting corridors from Civil 3D?
Warm regards,
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Hi Projetos,
Thanks for reaching out, and thanks @hagen.deloss for tagging me. I've moved your post to the Civil 3D forum to ensure you get more responses from experts in that area.
Meantime, I highly recommend checking out this video by CTC, which explains the workflow of using the 3ds Max Civil View Add-In for creating visualizations. It's an excellent resource to get you started on the right track.
