How can I get the existing road assembly to show as existing? Currently it comes in the same as my proposed in cross section. I need to display existing with a different color and dashed lines.
C3D 2018, latest updates
WIN 10
Solved by cwr-pae. Go to Solution.
Use subassemblies that allow you to change the codes, assign codes as "e-pave", "e-base", etc. and add the codes to your code set style to show as needed. The "GenericPavementStructure" sub allows user codes.
