Does any one know what the yellow square with the exclamation symbol means next to dimensions.
We are all of a sudden getting this symbol and its confusing the engineers when they look at the actual cad file.
What is it and how do I turn this off.
I have never had this problem before.
2018 in Use
Dave Z.
2018 in Use
Dave Z.
I have just discovered that when the above symbol appears a can not edit the text within the note or dimension.
In order to make a correction I have to delete the note and add it back in. And yes I get the yellow square symbol again.
grrrrrrrrrrrrrrrr
grrrrrrrrrrrrrrrr
hi @Anonymous ,
See if this helps:
https://forums.autodesk.com/t5/autocad-forum/exclamation-mark-with-the-dimension/td-p/3510894
hi @Anonymous ,
See if this helps:
Thank you. For some reason the "Annotation Monitor" (Bottom Right Corner) had been turn on.
Glad that you found the solution!
