Civil 3D Forum
enter name of drawing to open??
38 REPLIES 38
Message 1 of 39
126609 Views, 38 Replies
after a recent crash civil 3d now asks me to type in the full path and file name for a file i want to open after selecting the open option on the menu or toolbar.
i know there is a variable that requires re setting but i don't know how. advice gratefully recieved.
thanks!
Tags (1)
38 REPLIES 38
Message 21 of 39
Syed_aligoher
when you open the Auto CAD then you wright fiedia enter then press 1 ok
Message 22 of 39
lutf80
Thanks a lot i have the same problem since half a month very helpful
Message 23 of 39
In C3d 2018. I'm getting this same prompt. I'm typing in "FILEDIA" and it says "cannot find specified drawing.." What should I do?
Message 24 of 39
Ajilal.Vijayan
Message 25 of 39
^^ thanks for the help reading this post helped fix the problem!
Message 26 of 39
Now I can tell there are more people saying the same as I do. I heard there are other softwares with more commom sense in their programing than this one. For Autodesk: K. I. S. S. (Keep It Simple Stupid).
Message 27 of 39
in reply to: troma
Thank you for your big help!
Message 28 of 39
filedia 1 really works! tnx for that new knowledge.
Message 29 of 39
Typing in this option also works for the original AutoCAD program, not just AutoCAD Civil
@Anonymouswrote:
FILEDIA=1
Message 30 of 39
neilyj666
@Anonymouswrote:
FILEDIA=1
Yes it does as Civil is built on AutoCAD.....in fact pretty much all the original AutoCAD commands work in Civil...!!!!!
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 31 of 39
Thanks a lot
Message 32 of 39
RunarPJCMNN
in reply to: troma
Worked perfectly, been trying to fix this stupid issue for ages!
Message 33 of 39
after i get : No system variable changed **** . what can i do abour it ?
Message 34 of 39
It has been a while since I had this problem and posted this question so I do not recall for sure.
for your question have you typed in sysvarmonitor (for system variable monitor) on the command line?
when I do this I get the System Variable Monitor box where I can change the variables or reset them all.
I believe I have reset them all before when I was having that problem  and it resolved the issue.
If the problem you are having is that you can not open a drawing using the 'open drawing' icon and it is wanting you to type the name of the drawing to open in the command line I think I fixed this issue before by opening the system variable monitor box and changing the FILEDIA variable to 1.  I think you can do this directly on the command line also by typing filedia and entering 1.
hope this is helpful.
Message 35 of 39
in reply to: neilyj666
çok teşekkürler kral
Message 36 of 39
in reply to: troma
Greatly appreciate that!!! Mark. that was very help full
Message 37 of 39
anita.michaud18
NONE OF THOSE SOLUTIONS ARE WORKING FOR ME.  WHEN I TYPE ON THE COMMAND LINE IT GOES UP ONTO THE BAR THAT SHOWS UP ASKING FOR THE FILE NAME,  I SEEM TO BE STUCK
Message 38 of 39
ME TOO
Message 39 of 39
terry2
When I attempt to open a drawing session, after I select  open I get a notice in a white box That says "entEr name of drawing" and my screen freezes and will not respond
Rail Community
